Asus z97 deluxe and 4770k overclocking WHEA ERRORS
not sure how the itx compares to the deluxe in terms of settings/overclocking though! if you want me to try any settings or anything just let me know :)
hope the new cpu fares better for you!
well this is a first under windows 7 64bit with 0801 bios
[/IMG]
whats it using atm?
only a few clicks above what its using,maybe 1.25v?
you shouldn't need to move the overvoltage jumper as a rule?
click on them any for cpu parity 19? some are for memory also but it will say
for 0 whea parity 19 you have to raise cpu voltage
yh if you double click on each error/warning it should say what they are for,cpu/memory/ssd ect
some wont matter its for software ect,but ones for cpu/memory will as they are causing the crashes
All I've been seeing is WHEA and 0 and have raised the voltage between 1.2 and 1.25 if I'm still getting these errors should I raise it again?
take a pic of the whea errors,does the pc still crash? if not itll be ok
if it is crashing then yh might need touch more cpu v
I will get some pictures in the morning I've put it back to default as it was crashing constantly its at 3.5 to 3.9 with xmp enabled with my ddr sitting at 2400.
