Do you get less camera shake when using the viewfinder VS LCD screen ??
Caporegime
27 Nov 2005
Guernsey
Has anyone notice if they get less camera shake when taking pictures using the view finder on a camera compared to using the LCD screen ?
In theory, yes, your arms is further out.
If the viewfinder is against your face you have a 3rd contact point to add stability.
Easier to hold it steady resting it against your face than free hand, but with good technique either works just fine depending on the weight of the camera.
I only ever use the LCD on my DSLR if taking pics at awkward angles, as I get far better results looking through the viewfinder as it's much more stable. Recently I was going pics of my Grandad's model railway so the LCD came in very handy then :)
Viewfinder unless I'm on a tripod or on a surface where the camera is just sitting. Live View is handy for those times and I imagine a tiltable screen would be nice too.
Though there was an app that I had on my phone that you could connect to your camera and IIRC see the live view output as well as control the settings on the camera.
i always use the viewfinder ...unless i cant
its much easier to actually see the pic
the lcd is userful.. i find the swivel/tilt etc on my 60D very useful in macro
Yes, as above.
Quite a big difference , you want the camera weight close to your body, and supporting it against your head add support.
This is one of the biggest I have with any of the mirrorless systems without a viewfinder.
