- 31 May 2014
Hello everyone,
I am looking to build a new gaming machine and would be extremely grateful for a few suggestions.
I currently have the below set up (sorry if it's not detailed enough):-
asrock extreme 4
3570k i5
kingston 120gb hyperx (boot)
Samsung f3 1tb (steam and games only)
seagate baraccuda 3tb (taken from external goflex)
2x WD Caviar Green 2TB (raid configuration for perishable data)
Corsair H60 Cooler
2x 4gb corsair dominator platinum 2133mhz
fractal design R4 Define Case
2x corsair sp120 on the back either side of my radiator.
2x corsair af140 on the front
Asus GTX670
OCZ Fatality 750W
My goal is to build a machine that will run 4K games at 60fps. I don't know how realistic this is right now or might be so expensive it's pointless I am not sure. if it is a case of running two GPU's that is fine or if I need a bigger case etc.
the plot twist is that my case is quiet and I like it that way. it currently runs front to back cooling
(not the most effective probably) I understand I may have to sacrifice this.
I also understand that newer or different processors may need more advanced cooling like a bigger radiator etc.
I don't mind putting extra sp120's on the top of the case in this case, but how effective is front to top cooling? and is it mega noisey?
I have my eye on a X9000B Series Sony 4k television upon the promise of HDMI 2.0 compatibility (so I can actually achieve 4k at 60fps)
Budget withing reason is around £1000 but presumably I will need new GPU's, processor, motherboard and case/cooling options and can keep the rest of the parts?
Thank you
asrock extreme 4
3570k i5
Corsair H60 Cooler
Asus GTX670
OCZ Fatality 750W
Thank you
