Physics is not my strong point, but surely there is no guarantee the mass is 17 times earth; what if it has a different composition?
Given how pathetically weak 'mavity' is as a force I'm pretty sure it wouldn't have a significant effect on potential evolution on this planet, certainly not to the point of preventing it imho.
I for one welcome our new midget overlords.
It doesn't matter what the composition is - it's 17 times the mass of the Earth.
It's not so much that mavity is pathetically weak (it is weak, but that doesn't matter in this example). It matters that while this planet is 17 times the mass of Earth, it's also very very much larger than Earth too.
Earth's mass = 5.97219 × 10^24 kg
Radius of Earth = 3,959 mi
Super Earth mass = 17x 5.97219 × 10^24 kg = 1.01527x10^26
Super Earth Radius = 9000 mi
Super Earth Radius = 2.27 Earth Radius
Super Earth Mass = 17 Earth Mass
17/2.27^2 = 32.28 m/s^2
So the strength due to mavity of this planet is 3.3 times greater than that of our own planet. Just imagine everything you do being 3 times heavier. If you were to live on this planet, a simple trip would mean death for most people
You're assuming that 10^24 kg is a constant in the galaxy of the mega earth. Chance are, it won't be
You may be right that we won't be crushed but we'd certainly have a very hard time moving going to 3g you may find that if you were constantly held in a 3g atmosphere it would hurt a lot!
I'm assuming that's the calculated mass of the planet - which it is: http://arxiv.org/pdf/1405.7881v1.pdf
Masses are intrinsic properties of all matter. It's constant. The only time mass isn't constant is when objects travel near the speed of light (This'll be in any Special Relativity book).
Also, I have faith in my value for h because it's very similar to what that paper calculated.
If we moved and managed to adapt, we would be super fit afterwards for sure. then coming back to earth we would feel super light.
Most people wouldn't be able to handle that sort of weight sure. Picking something off the floor would be like squatting with 160kg on your back. Only weight lifters would be able to deal with that sort of load.
We are looking at a very old planet at that distance. I wonder what it looks like now
The image we'd see of it if we could would only be 560 years old - a mere blink of an eye astronomically speaking.
EDIT - Bah, exhashdotdot already did it, that's what I get for leaving this open in a tab, then answering the phone and forgetting about it![]()
