Morning gents
I'm considering a little upgrade to my system, as I've been noticing it's just starting to shows its age slightly. I mainly play MMOs (ESO and Wildstar) but dip into some FPS games as well (which tend to be a little more demanding).
Current system is as follows:
Just wondering what the most effective upgrade would be. Happy to spend £200-350 ish.
Most of my games are installed on a SATA drive, rather than the SSD listed above, does that make much difference?
Thanks in advance for any advice.
- Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 (small overclock)
- Sapphire HD 7850 2048MB GDDR5 (small overclock)
- Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard
- Crucial RealSSD M4 128GB 2.5" SATA 6Gbs Solid State Hard Drive
- Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
- Gelid Tranquillo CPU Cooler
