- 30 Nov 2011
http://www.extremetech.com/gaming/1...opers-weigh-in-on-the-gameworks-controversy/4
Mantle gives AMD a competitive advantage, yes, Because it improves performance. Does it have the potential to have a negative impact on Nvidia GPU's / users? No, it has nothing to do with DirectX or Nvidia. Nvidia cannot be affected by it.
GW Gives Nvidia a competitive advantage through added features, Does it have the potential to have a negative impact on AMD GPU's / users? Yes. the GW libraries are a part of the game for both Nvidia and AMD while only Nvidia have full access putting AMD at a potential disadvantage.
This is not entirely true, if a dev signs up to mantle they are comitting time to implementing mantle, which will mean some time taken away from DX optimisation/bug fixing, same as with gameworks, there is nothing about adding a library that should negatively impact AMD's performance, but clearly signing up to work with nvidia is potentially going to skew performance results and can mean that less time is spent on AMD specific optimisation - this is nothing new, devs havebeen working with AMD and Nvidia for donkeys and there have always been games that perform marginally better on the sponsors hardware
The direct performance difference a library imparts is only when that library is actively being called, so turn off HBAO+ in game, that library is effectively no longer "part of the game" so the performance impact of that library is negated
The point Ikeep trying to make, along with Sin is that both tools are just marketing, neither AMD nor nvidia give a rats arse about "gamers" beyond how much money they can make, AMD are spinning things off as whiteknighting for gamers, but the truth is thet want to sell more product
, mantle has zero impact in hampering Nvidia performance-it cannot happen in any shape or form,impossible to the highest degree.
