Have you set the max fan speed to 100%? It shouldn't be throttling.
most of the aftermarket coolers are the same.
The peter 2 and the Morpheus are both pretty good. RJK tested the morpheus on his 290x before release had no complaints about it says it stopped the throttling.
(goes review hunting)Have you set the max fan speed to 100%? It shouldn't be throttling.
Sheesh, any more than 50% and I wanna jump through the window!!! I do have 2 though![]()
Tom's point is if you leave the temp target at 95c but set the max allowed fan speed to 100% the card will remain quieter without throttling than any other setup for a reference card. It won't get anywhere near 100% fan speed that's for sure.![]()
(happened twice now
)What AIO cooler will you be using though?Humm good point (i forgot that the MAX allowed fan speed was adjustable) that should work for the time being.
TBH iv settled on getting a NZXT KRAKEN (pay day impulse buy FTW).... but whenever i'm ready to order the VRM heat-sink pack is out of stock(happened twice now
You might want to have a look at the H75 as well.I was looking at the Hydro H55
We are waiting on vrm heatsinks the manufacturer eol'd it despite it being so successful we have suggested to a couple of other manufacturers that some slack could be picked up here. Rajintek were one of these as they make them already.
