Gaming PC £650 Budget
20 Nov 2013
Hey guys can someone spec me a gaming PC with a max price of £650, i don't need a monitor, OS or other peripherals.
I generally play World Of Warcraft but i have just sold my Xbox 360 so i would like my new PC to be able to play the new games so i don't miss out. thanks
Hi,
YOUR BASKET
1 x Sapphire Radeon R9 280 Dual-X 3072MB GDDR5 PCI-Express Graphics Card £199.99
1 x Intel Core i5-4590 3.30GHz (Haswell) Socket LGA1150 Processor - Retail £145.99
1 x Gigabyte Z97P-D3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £69.95
1 x Kingston HyperX 8GB (2x4GB) PC3-17100C11 2133MHz Dual Channel Kit - Black/Gold (HX21C11BGK2/8-OC) £61.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £55.99
1 x Corsair Carbide 200R Compact ATX Case - Black (CC-9011023-WW) £44.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £43.99
1 x Raijintek Themis Direct Contact CPU Cooler £19.99
Total : £657.89 (includes shipping : £12.50).
Non-K CPU so no Overclocking, but a Z97 platform to support Fast RAM. (only a few £ cheaper than a decent H97 board.)
would have liked to have an SSD in for you, but that'd cost an extra £60. If you can push your budget that much i'd very much suggest it. :)
Aidos will be slightly louder than the Themis :) Themis will fit fine in Neos as it has 160MM CPU clearance.
But for the sake a of crispy blue/green note why note get the better quiter version. :)
Now you've given me the urge to play monopoly again!
no can do. not on that budget unfortunately.
i didnt deliberately omit the hdd ;p that's why i specced a 256gb ssd, that could serve as the main + some storage until op saved up 50 quid more to get a hdd =x
(i'm moving away from 120gb ssds on specs...i think they're not worth their money anymore, an extra 20 quid can double the ssd storage)
