Caporegime
- 21 Jun 2006
High Frequency Network Update
For the PC, PS4, and Xbox One platforms, we are adding something we nicknamed the “High Frequency Bubble”.
Within a certain radius of the player, we add the possibility to update the clients at a higher rate from the server. What this essentially means is that the server will update the client on what is happening more often than before. This normally results in a smoother, more “correct” player experience.
The High Frequency Update is by default turned OFF in this release. You will have to enable this setting to take advantage of the improved networking. To support players with a limited bandwidth connection, we support three different levels: LOW, MEDIUM and HIGH. Most players with a connection faster than 1Mbit upload and 1Mbit download should be fine using the HIGH setting. If you experience any issues, lower or turn off the setting completely.
Playstation 4 & Xbox One Server Performance
The High Frequency Update will be rolled out to all 48 player servers and on a small set of 64 player servers immediately. We will then keep a close eye on the larger servers to make sure server performance stays good in the live environment. If all goes well, all servers will be supporting the high frequency update after 24 hours or rollout and testing.
PlayStation 4
• Improved/reduced explosion induced camera shake
• Rental server bug fixes
• Character collision improvements
• Fix to reduce object damage mismatch between client/server.
• Fix explosion packs not being able to be shot sometimes
• Improvements for client side packet loss
• Added controller option to swap functionality of the bumper and trigger buttons
• Physics optimization for Naval Strike Wave Breaker rocks
• Carrier – Invisible walls stopping bullets fix
• High Frequency Network update
- Added High frequency “bubble” updating player movement, stance, rotation, damage and projectiles at a separate rate on foot and in vehicles
- Added option to control client side update rate setting
PlayStation 4
its confusing between the names on the forums, your psn ids, then your real names that come up on the dashboard, but not in game...
How the hell can anybody get any enjoyment out of playing that?
