Tell me or you have a 24 TS ban incomming.![]()
Does it only work for AP shells?
I think the cat is now out of the bag with regard to this "bug" you might as well just post it up.
Only if you ban Chipmunk first
Will tell you guys later on TS, rather not have everyone knowing![]()
bing..... bing..bing...............bing..bing...bing..............................bing
So yeah, nexus morse code![]()
ummmmm I think I may have found it, 2 shots and the tank explodes. If it is the same spot then you are right it is very small and extremely hard to hit on a moving tank. To be honest I think I would rather stick with Sabots and be able to hit targets out to longer ranges.
You mean
Oh it works with sabot too!
Keeping to sabot then!![]()
Yeah it works with sabots too. Amazed haven't done it by mistake.
Just loaded Origin and it's showing the store in russian (I assume).
Any ideas? (not using proxy, language set to english GB etc).
Someone has hijacked your account and changed your preferences?
Check your battlelogs and origin!
Battle log still shows UK. Even if I load up a web browser and try and get into origin it shows the russian store. Traced my IP and it's showing my correct location. :S
