The Battlefield 4 Thread ~ Server details in opening post ~
Status
Not open for further replies.
Only if you ban Chipmunk first
Will tell you guys later on TS, rather not have everyone knowing :p
Done, and will that be you verbally informing us, or a just a series of "bings" - or as we affectionately call it Nexus morse code.
ummmmm I think I may have found it, 2 shots and the tank explodes. If it is the same spot then you are right it is very small and extremely hard to hit on a moving tank. To be honest I think I would rather stick with Sabots and be able to hit targets out to longer ranges.
Trading shots at point blank range I think you could hit it quite easy.
Yup sounds like you found it.
Pretty much my thoughts too, just depends on your play style tbh, I like to keep my distance so I'll probably switch back to sabot within 1 round tonight :p
Got my trusty HMG for infantry, just ask Tony and kerukly ;)
You mean
:D
Oh it works with sabot too! :eek:
Keeping to sabot then! :p
If it's what I think it is (just been in the range) I can't see why it wouldn't. It's where not what. It's just that the AP and Sabot are easier to get a hit at the right point from a distance.
Battle log still shows UK. Even if I load up a web browser and try and get into origin it shows the russian store. Traced my IP and it's showing my correct location. :S
As it happens mine too :eek:
I guess origin (or europe) has been annexed.
I'm thinking this 2 hit spot is really there for the attack jets, I wondered why their zunis seemed to be twice as effective as the LAV.
*runs off to see if LAV can exploit*
Edit: Yup 1 round of zunis from the LAV if you can get them all to hit. Mostly even at a standstill you won't get them all on the target, but a mopup with the 30mm and it's done.
Edit2: Boom headshot :)
Status
