Sniper Elite V2 Benchmark
:D
Sniper Elite V2 Benchmark Report
Created: 2014-06-07 at 19:01:27
Build Version: 1.13, May 23 2014
Average FPS: 60.0
Minimum FPS: 31.5
Maximum FPS: 275.0
Number Of Frames: 4601
Average Frame: 16.658ms
Minimum Frame: 3.636ms
Maximum Frame: 31.752ms
Machine Name: PCJAMESNYGREN
Monitors: 2
Operating System: Windows 7 Ultimate Edition Service Pack 1 (build 7601), 64-bit
System RAM: 8085MB
CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
Number of Cores: 4
GPU Name: NVIDIA GeForce GTX 780
Feature Level: DX11.0
Driver version: 9.18.13.3788
Dedicated VRAM: 2994MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Advanced Shadows: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Compute Shaders: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
:D
Average FPS: 60.0
Minimum FPS: 31.5
Maximum FPS: 275.0
Monitors: 2
System RAM: 8085MB
Number of Cores: 4
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
What clockspeeds were you using for you CPU and GPU please.:)
Only just spotted this and thought I'd give it a go. Surprised to see so few AMD CPU's in the list... well that's about to change. Here's my results:
Created: 2014-06-12 at 16:37:24
Average FPS: 38.0
Minimum FPS: 20.7
Maximum FPS: 288.5
Number Of Frames: 2908
Average Frame: 26.316ms
Minimum Frame: 3.466ms
Maximum Frame: 48.422ms
Machine Name: TMB8350
Monitors: 1
System RAM: 16281MB
CPU: AMD FX(tm)-8350 Eight-Core Processor @ 4.2ghz
Number of Cores: 8
GPU Name: AMD Radeon HD 7970 Matrix Platinum
Driver version: 8.17.10.1267
Dedicated VRAM: 3046MB
CPU Clock: 1100mhz
Memory Clock: 1650mhz
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Created: 2014-06-12 at 23:18:32
Build Version: 1.05, Jun 7 2012
Average FPS: 32.7
Minimum FPS: 19.0
Maximum FPS: 123.8
Number Of Frames: 2492
Average Frame: 30.626ms
Minimum Frame: 8.075ms
Maximum Frame: 52.645ms
Machine Name: NIKI-PC
Monitors: 1
Operating System: Windows 8 (build 9200), 64-bit
System RAM: 16270MB
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Number of Cores: 8
GPU Name: AMD Radeon R9 200 Series
Driver version: 8.17.10.1280
Anti-aliasing: HIGH
Supersampling: 4.0x
Compute Shaders: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Are my settings good?
4770k stock and R9 280x at stock too.
'Kaapstad' I presume I can overclock and tweak both my CPU and GPU and then submit another score that (if better) will replace my current score . . . If so I know what I'll be doing tomorrow :)
Overclocking is fine, looking forward to your score.:)
Once I get a DC and the V2 Skyn3t Bios I will try again (found out my 780Ti is newer ones with newer bios that does not play nice with V1 Bios).
3930K @ 4.6 - SLI Titans at 1267/3758
