hmm these are £380 new unlocked on ebay daily deals now
Just a heads up, these particular ones are Korean/Asian imports - hence the G900H code instead of European G900F. Major difference is the Korean ones DO NOT HAVE 4g but do instead have the Octo Core processor.
You would need to make sure you know which one you want.
CerberusGot mine today. Still finding my way around it
Any apps I should install?
Got mine from 02, £25 pm for the handset 0% APR over 24 months in the 02 refresh plan £15.99 for 5GB of 4G data and unlimited calls/texts. Use an open code for 30% off tarrif cost. No upfront cost. £600 total credit for the phone, usually pay off in 5 months so I only pay £15.99 and can upgrade early.
Have an LG G2 too and prefer the LG, bit dissapointed tbf, but overall an excellent package, the camera is superb.
^Looking very good. This is what the S5 should've been in the first place.^
I hope Samsung make it available in the UK and the price isn't too expensive I'd be seriously tempted.
How are people finding the charging port cover?
Is it flimsy or really sturdy?
Just ordered my S5. Can I charge it wirelessly with one of those pads? What are the best options?
Prime looks a little better than the standard s5 with that horrible back. The prime should have been the standard s5.
