With looking to ever increase our range of sound peripherals at OcUK in line with our coming expansion to Audio headsets and DACS I'm happy to announce that we will be listing a range of Blue Desktop Microphones.
These high quality microphones bring professional quality to your desktop perfect for Shout-casting recording voice-overs or just talking to friends and family.
More will be added shortly to view the whole range please click here.
Blue Microphones YETI @ £99.95 inc VAT
The Yeti is one of the most advanced and versatile multi-pattern USB microphones available anywhere. Combining three capsules and four different pattern settings, the Yeti is an ultimate tool for creating amazing recordings, directly to your computer. With exceptional sound and performance, the Yeti can capture anything with a clarity & ease unheard of in a USB microphone.
The Yeti features Blue's innovative triple capsule array, allowing for recording in stereo or your choice of three unique patterns, including cardioid, omnidirectional, and bidirectional, giving you recording capabilities usually requiring multiple microphones.
The Yeti utilizes a high quality analog-to-digital converter to send incredible audio fidelity directly into your computer, a built-in headphone amplifier for zero-latency monitoring, and simple controls for headphone volume, pattern selection, instant mute, and microphone gain located directly on the microphone. There are no drivers to install - simply plug the Yeti into your PC or Mac, load up your favorite recording software, and record something amazing.
Key Features
- Power Required/Consumption: 5V 500mA (USB) 4V DC (Analogue)
- Polar Patterns: Cardioid, Bidirectional, Omnidirectional, Stereo
- Frequency Responce: 20Hz – 20kHz
- Weight: (microphone) 1.2 lbs/0.55 kg (stand) 2.2 lbs/1 kg
- Dimensions: 12 x 12.5 x 29.5 cm (extended in stand)
Only £99.95 inc VAT.
ORDER NOW
Blue Microphones Yeti PRO @ £188.95 inc VAT
The Yeti Pro is the world's first USB microphone combining 24 bit/192 kHz digital recording resolution with analog XLR output.
Featuring three custom condenser capsules and four different pattern settings, the Yeti Pro can capture digital audio with up to four times the clarity found on CDs.
Plus, the Yeti Pro features a cutting-edge A-D converter chip and separate analog circuit path for usewith professional studio mixers and preamps.
You also get a built-in headphone amplifier for zero-latency monitoring, and direct controls for headphone volume, pattern selection, mute, and microphone gain.
So whether you record at home, in a studio (or in the Himalayas!), the Yeti Pro is your ultimate sound solution.
The legend of the Yeti continues with the most advanced and versatile multi-pattern USB microphone roaming the wild today.
The Yeti Pro features tools and recording capabilities usually requiring multiple microphones and devices, all with the simplicity of a plug 'n play USB microphone.
Desktop or studio, the possibilities are endless
You can quickly select from each of Yeti Pro's four pattern settings (stereo, cardioid, omnidirectional, bidirectional) by simply rotating the pattern selector knob.
Stereo
The Stereo mode is great for capturing a realistic stereo image.
To start, point the microphone at the sound source that you want to record (the "front" of the microphone is the side of the microphone with the Blue Microphones Logo).
Depending on the instrument and/or sound that you want to achieve, place the grill of the microphone anywhere from 2 inches to several feet in front of the sound source.
By centering the sound source, you will get equal amounts of signal in both the left and right channels.
If you want a little more of the signal in the right channel, move the sound source a little to the right side of the mic (as if one is behind the microphone), and if you want a little more of the signal in the left channel, move the sound source to the left (as if you are behind the microphone).
Alternatively, you can record everything as centered as possible, and easily adjust the position when you're mixing the recording.
If you want the sound in the right or left channel only, you should try using the cardioid, bidirectional or the omnidirectional setting, and use your software to hard-pan the sound to the left or the right.
Cardiod
Cardioid is the most commonly used mode and can be useful in most any situation.
If you are recording vocals, a podcast, or a voiceover, cardioid is likely your best choice.
When recording in cardioid, sound directly in front of the microphone is picked up while the sound at the rear and sides of the microphone is not picked up.
Therefore, you will want to arrange the source directly in front of the microphone. Cardioid will deliver the most direct, rich sound, but will not offer as much airiness or presence as the other recording modes.
Omnidirectional
Omnidirectional means that the microphone picks up sound equally from all directions.
This setting is perfect for recording a group of musicians all playing at the same time, recording a conversation between multiple parties around a room, a conference call, or any other situations where you want to capture the ambience of 'being there.' Because sound is picked up from all directions in this mode, the orientation of the microphone isn't crucial, but as a good rule of thumb, start by orienting the front of the microphone at the primary sound source you wish to record.
Bidirectional
Bidirectional means that the microphone picks up sound at the front and rear of the microphone, while the sounds to the sides are "rejected", or not picked up.
The bidirectional setting is very useful in achieving a nuanced, pleasant sound when recording musical instruments, and is perfect for recording an interview with two or more guests.
By placing the microphone between two or more subjects (front of microphone facing one source, rear of microphone facing another), you can achieve a natural sound without the complexity of using multiple microphones.
Key Features:-
- Frequency Response: 20Hz – 20kHz
Only £188.95 inc VAT.
ORDER NOW
Blue Microphones SNOWBALL - GLOSS BLACK @ £64.99 inc VAT
Whether you're recording a guitar at your kitchen table or a complete band in the studio, the Snowball can capture sound with detail unheard of before in a USB mic. Plus, it's a direct plug and play mic that connects to either a Mac or PC - no additional software is needed.
Record anything from vocals to a full band
With its dual capsule design and unique three-pattern switch - cardioid, cardioid with -10dB pad, and omni - the Snowball can handle everything from soft vocals to the loudest garage band - and it's ideal for podcasting.
Highlights
- Professional condenser microphone
- USB powered
- Plug and play functionality
- Unique three-pattern switch
- Dual capsule design
What's in the Box?
- Snowball microphone
- 6-inch stand
- USB cable
Tech Specs:-
- Frequency Response: 40Hz - 18kHz
- Connections: USB
- Weight: 2.25 lbs.
- System Requirements
- Mac Mac OS X v.10.4.9 or later 64 MB RAM USB 2.0
- Windows Windows XP (SP2)/Vista/7
Only £64.99 inc VAT.
ORDER NOW
Key Features
ORDER NOW
Stereo
Cardiod
Omnidirectional
Bidirectional
Key Features:-
ORDER NOW
Highlights
- USB powered
What's in the Box?
- 6-inch stand
- USB cable
Tech Specs:-
- Connections: USB
- Weight: 2.25 lbs.
ORDER NOW
