Hi peeps,
Just basically upgraded my board to a MSI Z97i gaming AC , really working a treat for me. Fine board. I've also changed case to a Obsidian 250D , and using an old H80 cooler in push pull.
Now I've managed 4.6ghz on my 4670k, tightened my ram down to usual 10-11-10-27-1T @ 2400mhz.
At 4.6ghz I'm using 1.31v on core / 1.19v on ring / SA volts are 1.065 / all other dig/analogue/ are around 1.025v. The vvci input voltage is at 1.94v
So what are the exact limits here, as this little board wants more I can feel it. As mentioned using h80 and doing normal usage and benchmarks such as cine bench and super pi it's max temp was 67 degs.
Thanks, more detailed info welcomed.
