Private/local seller advise needed
Nah just connect the GPU up, update drivers, run the tests i told you about. in that order or doing drivers first, either is acceptable
update for you guys
had little scare actually two scares it wasn't detecting the gpu black screen when i booted it up no signal at the screen after playing about with it i noticed that my mobo has gpu on/of switches for each lane even way got on both green power lights on and the fan started spinning.
went straight to geforce exprience downloaded and i had update, updated it and asked for restart and after the restart i had no signal after windows 7 screen restarted did the recommendation option thingy and it worked back in checked geforce and im up 2 date with 337.88 driver.
i have microsoft updates too should i update them too.
after that im going download after burner and heavens, lol im sat next to the gpu its so quite ^^
Yea with MSI Afterburner you can enable On-screen display monitors of GPU temps, fanspeed, GPU and memory usage...and recent added monitoring for CPU temp and usage as well! You can also set up a custom fanspeed profile as well.
Hope it all goes well with the card. If everything is fine, you might not only have gotten yourself a bargain, but may be a new friend as well (if you keep in contact with the seller, since you guys seem to have so much in common) ;)
i missed your post some how thanks a lot for taking the time to read my thread and helping and supporting us
first time going to test it in heavens, do i let it run till it finish or his there time limet i should aim for and does give you score or anything how would i know it has passed?
update for you guys
Just game with the card as you would do normally. If there's any abnormalities with the card, gaming will soon pick them up.
wright got tht f9 and with the msi do leave every thing to default only thing have done is gone in settings and trend on monitoring tab and checked show in on screen display.
[QUOTE
once you have that sorted, go ahead and run MSI after burner, take a look through the options screen for onscreen display and set it up.
Then run heaven on these settings
change res to your screen res if your not running 1080p
and click run, good luck :)[/QUOTE]
are those the correct input data fields i got fill in
ok im done so what info do you need.
i took screen shot of benchmark
msi temps
gpu temp
core clock max
memory clock max
power limit max
1 question where can i see or verify that my gpu is at stock
