Man of Honour
- 8 Nov 2007
- Outer Space
pair of second hand 280xs and change
Even on the MM that'd be a tall ask, plus his PSU wouldn't be up to it.
Thanks all.
Yea will have a look at those suggested. Just couldn't be doing with constant overheating. i did have a flick through the GPU section here and it seemed like every other post was a complain about the 290's either overheating or bad driver problems. But if those one linked are ok, then i might consider one of them.
I dont have £300 to spend normally so want to use it wisely.
Thanks all.
if i can get a second hand GTX 780, would that be a safer option. ? Still with warranty aswel mind.
how would 2 x 280x fair in the fps competition ? I do need a new PSU so could use just the one card until i get a new one.
I dont mean to harp on about it, but was looking at the specs of one of the GPUs suggested http://www.overclockers.co.uk/showproduct.php?prodid=GX-017-VX&groupid=701&catid=56&subcat=1752 and it says min 750w PSU.. I dont have that
OO and what about a HD 7990, they seem to perform very well. can pick up a second hand one for about that price
