but lets face it for commutes to work most people will be on the roads, having the extra acceleration and viability + noise can be a life saver.
edit: can take bikes on Byways and UCR
You certainly have a point about 125s, but it comes down to each person's specific circumstances. 80% of my commute by distance is on B roads, but this is only 20% of my commute by time.
When I hit the town roads, it takes me 15 minutes to do the 2 miles through town in a car, due to the queuing caused by hilarious quantities of traffic lights. I can do this same 2 miles in 6 minutes on my bicycle, because I can easily jump all the queues, even if there are cars in the other lane coming towards me. On a 125, this would not be so simple.
This is why an e-bike is very interesting for me. It's also a lot cheaper to run and fuel than even a 125 is.
Also, what's this rpm business?
http://www.greenbikekit.com/36v-250w-gbk-100f-front-driving-e-bike-kit-with-bottle-battery.html
£286 delivered. Might get import duties, might not.
I suppose the question is are you happy buying direct from China or do you want to use a UK company selling Chinese bits with a 40% markup?
I am looking to maybe get one of these kits for this:
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_810737_langId_-1_categoryId_165534
you think it will do well with that combination? I wouldnt mind buying direct.
saves me moneywould you recommend the greenbikekits or the bmsbattery kits?
If you can derestrict the speed by adjusting a setting on the display, then it's not legal.
Many certified bikes allow you to adjust the setting on the LCD.
What is that hidden break sensor for?
Amiga have you tried any of these gbk kits? I heard the 100h is better than the 100f?
Give me an example? I'm not aware of any legal bike that lets you adjust the max speed above the legal limit via the display.
Woosh bikes.
The 350w are illegal tho right? If stopped by chance and checked I heard they can take points off ur license?
Id rather stick to the legal then derestrict it so they wont be able to tell its derestricted.
Would you recommend the 100f? With the samsung battery 10ah? I was thinking to just get the 100f kit without battery and get the battery from . woosh as its 15ah square bottle but I can't find the kit without the battery?
