Crossfire Newbie - R9 280 to crossfire with Sapphire 7950 OC
15 Apr 2009
Hello All
I think I've nearly come to a decision and am reasonably decided that I will give crossfire a go for the first time! :D
My spec is in my signature and I'm looking to get a R9 280 (don't think there's much point spending extra to get a R9 280X). :cool:
Considering the extra heat, it looks like it would be a wise decision to get one that exhausts heat out of the case but all the R9 280s available on OCUK don't seem to do that, or am I interpreting the coolers incorrectly?! :confused:
I would like to check reviews but they seem to be few and far between... :eek:
I think I need to dump some of my superfluous HDDs to free up power connection to the PSU. Is there anything else I need to think about before taking the plunge? :confused:
Thanks in advance! ;):cool:
You look good to go. You can crossfire a 7950 with a 280X. Just make sure you have a decent space between the cards and good case airflow. OcuK don't sell any exhaust 280X's.
Thanks. Any exhaust 280s? Theres no point spending extra on a 280X is there?
Here's a pic of the MB - should be fine shouldn't it?
The only exhaust (280X/280/7970/7950) card you'll find Brotein Shake is a HIS 7950 Ice-Q Boost. (or non boost)
All the other cards will dump heat in the case. Good luck finding a HIS 7950. Auction site might be your best bet.
After searching through some related threads I see mention of potential bios flashing. Is this something I would need to look into? My 7950 is non-boost version and will be going with R9 280. If I use any OC'ing software, it will be MSI Afterburner...
Thanks again!
Thanks again!
Bump.
Worst case I guess is seeing if it works and if not researching how to flash bios...
Thanks again!
If you have the non boost version i think you'll be ok. If not i can always alter a bios for you.
I'm here if you need me. (no homo)
post jack, SORRY.
having problems over clocking my 280X DUAL-X OC. is my problem because there poor clockers or is the boost making problems. if its boost is there a bios that will remove the boost?
post jack, SORRY.
Are you increasing voltage? I doubt the bios has anything to do with it.
Mmmmm, some tempting deals now at OCUK for a R9 280. Was thinking I was going to have to go elsewhere for the best deal.
Are the other brands worth the premium over a VTX3D @ £150?
