I have 4770k and R9 295x2
and i would like to cool them with water,
i just bought off MM a watercooling case + internal watercooling loop :
Information :
Xigmatec eylisum this is a mamoth case. Current configuration is 2x 360 rads thick ones with room to still fit a htpx motherboard.
This case supports everything you can throw at it.
SSI form factor motherboards dual psu's 140 mm fans etc.
Case bundle pricing including installed WC kit
Kit comprises of:
1 Case as above
2x 360mm rads - not matched one white one black, pre-installed and connected
6x WC fans as per pictures in above link
1x fan controller
1x EK supreme nickel block EN version with universal and 2011 mounting kits.
1x EK DCP v4.0 pump res as per picture
fittings + tubing pictures + additional which are currently not installed (around 15pc additional assorted types and angles)
OCZ ZX 1250w PSU
http://s271.photobucket.com/user/kerrgreg2111/slideshow/Watercooling - xigmatek?sort=3
pictures
I have no idea where to start with the build
like knowing how to fill it and leak test it before i fit it.
i plan on cooling my cpu at first then my graphics card
the preloop thats installed goes from cpu to top 360mm rad with fans blowing out then from that rad to the 2nd 360mm ran that seems to be sucking air in not sure if it should be sucking in or blowing out that rad is on the front of the case
then from that rad to the pump/res then from the res to gpu then gpu to the cpu
but im not that great with watercooling but i really want to give it a shot i think i have all the tools and stuff i need i have some mayhems blue die and red die so all that i would need is the distilled water right
any tips help would be great
i also plan on upgrading to a 2nd 295x2 or 1 r290x is 2x 360mm rads cool enough to cool all that with great performance ? or would it be to much for the rads also like i said im new so any help or anything i need please jump in as im dieing to get all this stuff setup at the weekend
i
Information :
Kit comprises of:
1 Case as above
1x fan controller
OCZ ZX 1250w PSU
pictures
i
