Metal Gear Solid: Ground Zeroes
collected the lot of them but was under the impression that there was 2 side missions 1 specific to each console
Yeah Deja Vu was playstation platform exclusive and Jamais Vu was XBOX platform exclusive and then later on in an update both exclusives were free and multi-format. I'm on the PS4 and the Jamis Vu mission was added automatically in an update.
Ok thanks! Without spoiling anything for me.. are they obvious? If I put effort into searching for them will I have much trouble? Or are they stupidly difficult.
I used a guide, if you search and search you might find them yourself, although there's one in particular that was cleverly hidden in plain sight.
Hold-up the patrol gaurds and extract information from them because you never know what they might tell you, if you accidently knock out a gaurd that you haven't interrogated yet just kick em when they are down and this wakes em up, then point your gun at them and they will auto surrender and then you can interrogate them for info.
Thanks, I managed to find 5 by myself. I spent 90 minutes exploring everything but lost track of which guards I had interrogated. Will try for the remaining four tonight.
Easy way to remember is after interrogating the soldiers for info order them to lie down that way you'll remember the ones laying down are the ones you interrogated, if an alert is set off over camp omega the one's you ordered down on the ground will get up and be in alert patrol mode. I wasn't quite sure how kojima productions had programmed the A.I, in alert mode they can do a fairly thorough search for you, in one case scenario i had 4 soldiers checking my last known position, i had to eventually hang off a cliff side to evade the shoot out, hahaha :D
Really enjoying a bit of MGS action again after grabbing this in the Shopto deal for £17. Was doing the assassination mission just now and my second target decided to get into a jeep just as I was closing in after a minute of tracking him. His bodyguard saw me approach so it set off reflex mode, I shot both bodyguards the jeep driver and the target with 4 finely placed bullets. I can see why it's being called a tad easy in that respect, but it made me feel like a ninja super spy.. so I'm leaving it on.
Just kill the guards you have interrogated :p Using night vision helps a bit too since the patches glow.
I tried finding them all myself and found all but two. Took ages. One problem is that the guards will give you locations for patches you've already obtained. I must have gone through the level 5+ times searching all over and interrogating every single guard. Got a bit sick of it after that and looked up the last two online. There's one which I don't think I would have found in a million years so I'm glad I didn't keep searching myself.
Just managed this.
