Couple of quick q's
31 May 2014
Am overclocking my i5-357k Ivy bridge on a Gigabyte Sniper M3 board and can hit 4.3GHz with an offset of -0.04, CPU-Z reports 1.272 core voltage whilst running prime. I may be able to add even more offset subject to some more testing. Anyway, bumping the multiplier to 44 for a 4.4GHz overclock and I have to dramatically raise the offset to +0.01 and it still isn't fully stable - temps are in mid 80's and core voltage is around 1.35. So -
1) Will a different motherboard likely lead to a better overclock at 4.4GHZ with stability at less voltage / temps?
2) Will adding two more sticks of ram affect any overclocking stability? (My ram is running stock, no overclock applied)
1) No, like any CPU you play a lottery its the luck of the draw how well it overclocks and at what voltage especially Haswell.
2)Yes it can.
Running on stock cooler?
No, have got it on a Noctua NH-U12S and took delivery of an NH-D15 on Saturday which I have yet to install. I don't think my cpu will hit 4.4 without levels of voltage I'm not really happy to go to.
As a side note, my pc NEVER crashed when stress testing my overclocks with Prime, however browsing the net with IE or playing a game would show the instability / crash. I would have expected the other way around.
Thanks as always for your input guys.
Sometimes with speedstep enabled the core voltage will drop lower than what is required when the CPU is idle/near idle, so usually a bump in voltage would solve this but mean higher voltage when stressed.
You might have more luck disabling speedstep and just running at a constant clock/voltage.
Also even though benchmarks pass it won't be its 100% stable. I can pass benchmarks on GPU but crash in seconds in demanding games.
Could try notch VTT up to see if that helps, I never had a need to though even at 4.6ghz on my 3570k
