** NEW GIGABYTE GAMING LAPTOPS NOW AVAILABLE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Gigabytes new range of laptops shall be arriving with ourselves in the next 2-4 weeks and here they are, check them out and be sure to place a pre-order to guarantee getting one of these super quick gaming machines. :)
GIGABYTE P27G v2-CF1 Gamer 17.3" Full HD Display, Intel Core i7-4710MQ, 8GB DDR3L, 128GB SSD & 1TB 5400TPM HDD, NVIDIA GTX860M 2048MB GDDR5 - Windows 8 @ £1,079.99 inc VAT
Unrivaled Performance with the all new Intel® Core™ Processor
Experience revolutionary battery life improvement, super-speed performance, ultra-fast image / graphics processing, and many other security protection capabilities with the Haswell platform 4th generation Intel® Core™ Processor. Built on the 22nm architectural process making use of the latest 3D Tri-Gate transistor technology allows for unrivaled performance.
Incredibly powerful gaming graphics revealed
Features a high-end NEW NVIDIA® GeForce® GTX 860M GDDR5 2GB graphics processor that supports NVIDIA® Optimus™, NVIDIA® PhysX™ and DirectX11 Technology! The P27G delivers an ultimate gaming experience even for the most heavy games.
Vivid Visual Enjoyment with the 1080p Full HD Matte Display
The 1080p Full HD matte display panel features a light scattering anti-glare layer, which diffuses light, eliminating reflections and delivering a sublime gaming experience.
Superior Backlit Keyboard
The P27G features a superior backlit keyboard that allows gamers to adjust the light to external conditions and makes typing and gaming in dimly lit rooms and dark conditions better and easier.
Massive Storage System
The P27K is able to pack up to mSATA 256GB SSD and two huge 1TB HDD. The dual-storage hybrid system delivers high-speed performance and massive storage options. With the incredibly large storage, it's easy to store all your work and stuff without ever needing external storage devices.
Built-in 3 DIMM memory slots for Extremely High Read/ Write Speed
The built-in 3 DIMM memory slots are expandable up to 24 GB. The DDRIIIL SDRAM consumes less power even when running memory-intensive applications such as graphics editing, thus prolonging battery life, the P27K will definitely give gamers the best experience they have never encountered before!
Realistic Surround Sound
The ability to clearly hear specific sounds in a gaming environment are just a few elements of the Sound Blaster™ Cinema Audio Technology. It provides exceptional performance by effectively eliminating sound distortion, enhancing volume and reinforcing even the smallest details of sound. The result is a high-fidelity audio experience that is perfect for gaming, music and movies.
Specification
- Display: 17.3", 1920*1080 Full HD
- Processor Type: Intel Core i7 4710MQ
- Processor Cores: 4 (8 Threads)
- Processor Clock Speed: 2.40GHz (3.40GHz Turbo Mode)
- Hard Drive Supplied: 1 x 1000GB
- Hard Drive Size: 1000GB
- Solid State Drive: 128GB SSD x 1
- Hard Drive Speed: 5400RPM
- Memory Supplied: 1 x 8GB
- Memory Size: 8GB
- Memory Type: DDR3L
- Memory Speed: 1600
- Memory Socket: 2 x SO-DIMM
- Max. Memory Support: 24GB
- Operating System: Windows 8.1
- Graphics Chipset: NVIDIA GeForce GTX 860M
- Graphics Memory: 2GB GDDR 5
- Chipset: Intel HM87 Express
- Optical Drive: DVD Supermulti R/W
- Microphone: Built-in
- LAN: 10/100/1000Mbps
- Wireless: 802.11 b/g/n
- Bluetooth: v4.0
- USB 3.0 Port(s): 3
- USB 2.0 Port(s): 1
- eSATA/USB3.0 Port(s): 1
- HDMI Port(s): 1
- VGA Port(s): 1
- Microphone Jack(s): 1
- Headphone Jack(s): 1
- LAN Port(s): 1
- Card Reader: SD/mini SD/SDHC/SDXC/MMC/RS MMC/MS/MS Pro/MS Duo
- Web Camera: HD type
- Security: Kensington Lock
- Dimension: 413*277.5*17.5~48.8mm
- Battery: Li-ion 8-cell, 5200mAh, 76.96Wh
- Product Weight (kg):3.2Kgs
- Warranty: 2 Years
Only £1,079.99 inc VAT.
ORDER NOW
GIGABYTE P35W v2-CF1 UltraBlade Gamer 15.6" Full HD IPS Display, Intel Core i7-4710HQ, 8GB DDR3L, 128GB SSD & 1TB 5400TPM HDD, NVIDIA GTX870M 6144MB GDDR5 - Windows 8 @ £1,259.99 inc VAT
Incredibly Powerful Gaming Discrete Graphics Revealed
Features the latest NVIDIA® GeForce® GTX 870M GDDR5 6GB graphics processor that supports NVIDIA® FXAA, Adaptive V-Sync technology! With the latest Ultra Boost technology you can easily choose the Extreme mode through an intuitive interface. Enjoy unrivaled power with an impressive score exceeding P7100 on 3DMark 11!
Incredible Design
The GIGABYTE R&D team utilized the highest standards for internal design as well as integrating the most powerful processor, graphics chip, and essential components into the 21mm, 2.26Kg super slim and lightweight body, making P34G the most thin and light gaming laptop in the world.
Ultimate Cooling
The innovative Supra-cool technology features dual heat pipes plus dual fans for the CPU & GPU, ensuring excellent thermal conductivity for outstanding cooling. This is our our goal for every GIGABYTE gaming laptop: high performance and superior stability.
Vivid Visual Enjoyment with Full HD Wide Viewing Angle Display
The 1080p Full HD display with 170° wide viewing angle and up to 72% NTSC wide color gamut enhances the color and delivers sensational images, bringing games to life from any direction you look at it . Also, use the laptop as a marvelous home theater for multimedia enjoyment.
The Dolby Home Theater Audio Technology provides exceptional performance by effectively eliminating sound distortion, enhancing volume and reinforcing even the smallest details of sound. The result is a high-fidelity audio experience that is perfect for gaming, music and movies.
High Performance, Massive Quad-storage System
The Quad-storage hybrid system delivers high-speed performance and massive storage options. With the incredibly large storage, it's easy to store all your work and stuff without ever needing external storage devices.
Specification
- Display: 15.6", 1920*1080 Full HD
- Display Feature: IPS Wide Angle Display
- Processor Type: Intel Core i7 4710HQ
- Memory Size: 8GB
- Max. Memory Support: 16GB
- Graphics Chipset: NVIDIA GeForce GTX 870M
- Graphics Memory: 6GB GDDR 5
- Wireless: 802.11 ac
- Bluetooth: v4.0
- USB 3.0 Port(s): 2
- USB 2.0 Port(s): 2
- HDMI Port(s): 1
- VGA Port(s): 1
- LAN Port(s): 1
- Card Reader: SD
- Dimension: 385*270*21mm
- Battery: Li-Polymer, 75.81Wh
- Product Weight (g): ~2.26Kgs
- Warranty: 2 Years
Only £1,259.99 inc VAT.
ORDER NOW
GIGABYTE P35W v2-CF2 UltraBlade Gamer 15.6" Full HD IPS Display, Intel Core i7-4710HQ, 16GB DDR3L, 2 x 128GB SSD & 1TB 5400TPM HDD, NVIDIA GTX870M 6144MB GDDR5 - Windows 8 @ £1,399.99 inc VAT
Incredible Design
The GIGABYTE R&D team utilized the highest standards for internal design as well as integrating the most powerful processor, graphics chip, and essential components into the 21mm, 2.26Kg super slim and lightweight body, making P35W the most thin and light gaming laptop in the world.
Ultimate Cooling
The 1080p Full HD display with 178° wide viewing angle bring games to life from any direction you look at it . Also, use the laptop as a marvelous home theater for multimedia enjoyment.
Specification
- Solid State Drive: 128GB SSD x 2 (RAID 0)
- Memory Supplied: 2 x 8GB
- Memory Size: 16GB
- Bluetooth: v4.0
- HDMI Port(s): 1
- VGA Port(s): 1
- LAN Port(s): 1
- Card Reader: SD
- Warranty: 2 Years
Only £1,399.99 inc VAT.
ORDER NOW
GIGABYTE P25X v2-CF1 Gamer 15.6" Full HD IPS Display, Intel Core i7-4710MQ, 16GB DDR3L, 2 x 128GB SSD & 1TB 5400TPM HDD, NVIDIA GTX880M 8192MB GDDR5 - Windows 8 @ £1,679.99 inc VAT
Features a highest level NEW NVIDIA® GeForce® GTX 880M GDDR5 8GB graphics processor that supports NVIDIA® FXAA, Adaptive V-Sync technology! With the latest Ultra Boost technology you can easily choose the Extreme mode through an intuitive interface.
Vivid Visual Enjoyment with the 1080p Full HD IPS Matte Display
The 1080p Full HD matte display panel features a light scattering anti-glare layer, which diffuses light, eliminating reflections and delivering a sublime gaming experience. Adding IPS Wide Angle Display, it literally bring games to life from any direction you look at it
Electroluminescence Backlit Keyboard
The P25X epitomizes an automatic light sensing backlit keyboard. This significant feature adjusts the light to external conditions and makes typing and gaming in dimly lit rooms and dark conditions better and easier.
High Performance, Massive Storage System
The P25X is able to pack up to two mSATA 512GB SSD and 1 huge 1TB HDD. It provides massive storage options and delivers super fast performance of 1000MB/s and 850MB/s read/write rate for gamers with mSATA SSD super RAID 0 technology supported. Use the power of Raid 0 technology to your advantage for co-op or sharing games, giving gamers an experience like never before.
Dynamic Sound, Truly Amazing
The unique 4 Dual-channel Stereo Speakers are designed to provide dynamic and realistic sound effects, along with a subwoofer that boosts the deep, punchy bass. The result is a high-fidelity audio experience that is perfect for gaming and multimedia.
Rear Dual Air Vent Design Provides Effective Cooling
The P25W adopts a unique dual heat sink design with dual air vents (one for the CPU and the other for the GPU), increasing its gaming stability. The unique venting system is able to effectively keep the laptop from overheating despite the powerful features under the hood in this machine.
Specification
- Memory Size: 16GB
- Graphics Chipset: NVIDIA GeForce GTX 880M
- Graphics Memory: 8GB GDDR 5
- Optical Drive: BluRay/DVD Combo Drive
- Bluetooth: v4.0
- eSATA/USB 2.0 Port(s): 1
- HDMI Port(s): 1
- VGA Port(s): 1
- LAN Port(s): 1
- Card Reader: SD
- Web Camera:1.0MP
- Keyboard: Backlight LED
- Dimension: 392 x 263 x 32.1~38.3mm
- Battery: Li-ion 8-cell, 5700mAh, 86.18Wh
- Product Weight (g): ~2.6Kgs
- Warranty: 2 Years
Only £1,679.99 inc VAT.
ORDER NOW
GIGABYTE P25X v2-CF2 Gamer 15.6" Full HD IPS Display, Intel Core i7-4710MQ, 16GB DDR3L, 2 x 256GB SSD & 1TB 5400TPM HDD, NVIDIA GTX880M 8192MB GDDR5 - Windows 8 @ £1,999.99 inc VAT
Specification
- Solid State Drive: 256GB SSD x 2
- Memory Size: 16GB
- Optical Drive: BluRay ReWritable Drive
- Bluetooth: v4.0
- HDMI Port(s): 1
- VGA Port(s): 1
- LAN Port(s): 1
- Card Reader: SD
- Web Camera:1.0MP
- Warranty: 2 Years
Only £1,999.99 inc VAT.
ORDER NOW
GIGABYTE P34G v2-CF1 UltraBlade Gamer 14" LED TFT, Intel Core i7-4710HQ, 8GB DDR3L, 128GB SSD & 1TB 5400TPM HDD, NVIDIA GTX860M 4096MB GDDR5 - Windows 8 @ £1,169.99 inc VAT
The 14" GIGABYTE gaming laptop P34G features a 4th generation Intel® Core™ i7 Quad-Core processor and latest NVIDIA® GeForce® GTX 860M gaming level discrete graphics. The P34G is able to pack a high-speed 256GB mSATA SSD and a large 1TB HDD* into its incredibly slim and lightweight body of only just 21mm and 1.76Kg. The exceptional Full HD AHVA display with wide viewing angle, Dolby Home Theater sound quality optimization technology, equipped with flagship gaming specifications is unprecedented in the history of gaming laptop. With state-of-the-art design, the P34G delivers a full throttle gaming experience. The P34G from GIGABYTE is its most stunning gaming laptop ever.
The Haswell platform 4th generation Intel® Core™ Processor is built on the 22nm architectural process making use of the latest 3D Tri-Gate transistor technology. It delivers revolutionary battery life improvement, breathtaking performance, ultra-fast image / graphics processing, and many other security protection capabilities. Enjoy the breakthrough performance that you have never experienced before.
Features the latest NVIDIA® GeForce® GTX 860M GDDR5 4GB graphics processor that supports NVIDIA® Optimus™, NVIDIA® PhysX™ and DirectX11 Technology! The P34G delivers an ultimate gaming experience even for the most heavy games. Enjoy unrivaled power with an impressive score exceeding P4800 on 3DMark 11!
Performance is the main concern when developing and creating the P34G gaming laptop. The GIGABYTE R&D team utilized highest standards for internal design as well as integrating the most powerful processor, graphics chip, and essential components into the 21mm, 1.76Kg super slim and lightweight body. Thus, making P34G the extremely thin gaming laptop on earth.
The P34G is able to pack up to mSATA 256GB SSD and a huge 1TB HDD. The dual-storage hybrid system delivers high-speed performance and massive storage options. With the incredibly large storage, it's easy to store all your work and stuff without ever needing external storage devices.
The P34G has a dual air vent design (one for CPU and one for GPU) that efficiently eliminates heat and keeps noise to a minimum. Despite the powerful features and thin form factor, the unique venting system is able to effectively keep the notebook from overheating.
The P34G masters an automatic light sensing backlit keyboard. This significant feature adjusts the light to external conditions and makes typing and gaming in dimly lit rooms and dark conditions brighter and better.
The ability to clearly hear specific sounds in a gaming environment are just a few elements of the Dolby Home Theater Audio Technology. It provides exceptional performance by effectively eliminating sound distortion, enhancing volume and reinforcing even the smallest details of sound. The result is a high-fidelity audio experience that is perfect for gaming, music and movies.
Specification
- Display: 14", 1920*1080 Full HD
- Display Feature: AHVA Wide Angle Display
- Solid State Drive: 128GB SSD x1
- Memory Size: 8GB
- Graphics Memory: 4GB GDDR 5
- Bluetooth: v4.0
- HDMI Port(s): 1
- VGA Port(s): 1
- LAN Port(s): 1
- Card Reader: SDXC/HC
- Web Camera: HD Type
- Dimension: 340*239*21mm
- Product Weight (g): ~1.76Kgs
- Warranty: 2 Years
Only £1,169.99 inc VAT.
ORDER NOW
GIGABYTE P34G v2-CF2 UltraBlade Gamer 14" LED TFT, Intel Core i7-4710HQ, 16GB DDR3L, 256GB SSD & 1TB 5400TPM HDD, NVIDIA GTX860M 4096MB GDDR5 - Windows 8 @ £1,319.99 inc VAT
The P34G packs with mSATA 256GB SSD and a huge 1TB HDD. The dual-storage hybrid system delivers high-speed performance and massive storage options. With the incredibly large storage, it's easy to store all your work and stuff without ever needing external storage devices.
Specification
- Solid State Drive: 256GB SSD x1
- Memory Size: 16GB
- Bluetooth: v4.0
- HDMI Port(s): 1
- VGA Port(s): 1
- LAN Port(s): 1
- Warranty: 2 Years
Only £1,319.99 inc VAT.
ORDER NOW
GIGABYTE P15F v2-CF1 Gamer 15.6" Full HD Display, Intel Core i7-4710MQ, 8GB DDR3L, 1TB 5400TPM HDD, NVIDIA GTX850M 2048MB DDR3 - Windows 8 @ £799.99 inc VAT
Features a high-end NEW NVIDIA® GeForce® GTX 850M DDR3 2GB graphics processor that supports NVIDIA® Optimus™, NVIDIA® PhysX™ and DirectX11 Technology! The P15F delivers an ultimate gaming experience even for the most heavy games.
Pioneered Hot Swappable ODD/HDD Slot Design
The ingenious design of hot swappable ODD/ HDD slot from the GIGABYTE team gives gamers many choices to choose from. Your options are a DVDRW drive or an additional 1TB HDD storage or slot in an empty case to maximize portability and travel light
Specification
- Memory Size: 8GB
- Graphics Chipset: NVIDIA GeForce GTX 850M
- Graphics Memory: 2GB DDR3
- Bluetooth: v4.0
- eSATA/USB 3.0 Port(s): 1
- HDMI Port(s): 1
- VGA Port(s): 1
- LAN Port(s): 1
- Dimension: 374*252*14~34.1mm
- Battery: Li-ion 6-cell, 4400mAh, 48.84Wh
- Warranty: 2 Years
Only £799.99 inc VAT.
ORDER NOW
The P35W's are pretty cool because of this handy feature:-
Outstanding Flexibility: Hot Swappable ODD/HDD Slot
The ingenious design of hot swappable ODD/ HDD slot* brings more choices as well as opportunities for gamers. The swappable bay can take a DVD RW drive, Blu-ray drive or additional 1.5TB HDD. Ultimate customization creates unprecedented mobility.
Hi there,
re P34g V2, I know the tech spec states the battery is the 47.73 Wh but it seems for the UK it comes with the 61.25 Wh. Kindly, could you have a double check as you do have some in stock?
