- 10 Jan 2004
Hi all,
So I just went through an ebay purchasing spree and got myself 3 R290s for a knock down price. However I have the challenge of running them in my Phantom 410!
They are running really hot obviously, and are reaching ridiculous fan speeds. It was an impulse and if I had thought about it I should have gone for the non-reference cooler models. However I am where I am, and have some experience (be it 4 years ago) with watercooling.
So my main questions are:
1) Will 2x240mm radiators be enough to cool this amount of heat, I am not after low temps, just a quieter rig with stable (high isn't an issue - below throttling) temps? - Any guidance on good radiators, the top one will need tro be <35mm and the other can be as deep as required?
2) I have been looking at the heatkiller 290 blocks, are they a good choice?
3) I have no idea about the CPU block though, I have a socket 2011 i7-3960x - any thoughts on this?
4) For the pumps and res I have been looking at the XSPC Twin D5 - Is this overkill for pump power?
5) Connectors, I am going to use some form of CF/SLI combo block or pipes for the cards, I am really keen on quick disconnect/connect for ease of use, etc.
Any guidance on this would be greatly appreciated.
Regards,
Annih
Regards,
Annih
