Which one?
7 Mar 2014
Bucks
Hi guys
I am getting a new graphics card soon and i am stuck between these two:
YOUR BASKET
1 x EVGA GeForce GTX 780 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-2781-KR) £389.99
1 x Sapphire Radeon R9 290 Vapor-X OC 4096MB GDDR5 PCI-Express Graphics Card (11227-04-40G) £359.99
Total : £759.58 (includes shipping : £8.00).
Price does not matter as they are about the same, give or take some
Does anyone know when the new nividia 800 series is going to be coming out?
Thanks for any suggestions
Will
I can vouch for the EVGA 780s - great cards, run pretty cool and quiet, and they look good in windowed cases too :)
But you'll be happy with either most likely, just depends on what games you'll be playing and if there any specific features you want.
What games do you mainly play? If they support PhysX (Batman, Borderlands, etc) or GameWorks (COD: Ghosts) then get the Nvidia. If they support Mantle (BF4, Thief) then get the AMD.
You can't really go wrong with either GPU, they're both excellent.
+1.
I wont be overclocking the cards, I play a lot of battlefields so it would need to be good for hardline and battlefield 5(when it comes out)
I like the titan cooler on the one I chose and since I would like it to have the geforce GTX writing on the top
Any clue to when the nividia 800 series is going to be coming out? I might overclock my 280x to keep the performance till it comes out
Most likely next year and if sooner near to Christmas. The real answer is nobody knows but i doubt it's any time soon. For BF you are going to want amd anyway as with your current CPU you won't be getting the best out of any top end Nvidia card. Mantle will make your cpu perform to it's best in any game that uses it.
AMD said new Gpu by the end of the summer, so im guessing Nvidia will be too, maybe august or even september, but my guess these won t be high end gpu more likely low-mid end
Looking at your cpu you will definitely want to keep an AMD gpu whatever you do. Mantle will offer a big performance boost for you, regardless of which AMD card you use.
