Can't recall hearing much Daft Punk but if you like listening to Jarre and Vangelis then the 702's or Q701's would take some beating. I listen to a lot of Yes, Oldfield, Jarre, Al Di Meola, King Crimson, ELP, Eric Johnson, Satriani and for this type of music the AKG's are a league above the others. I still prefer the Beyers for heavier rock as they have a more satisfying bass growl but most of the time I find myself using the AKGs.
I just went and had a listen to Daft Punk on YouTube, so quality wasn't the greatest, on the STX with both headphones:
There is a fair amount of bass on DP tracks and the Beyers definitely bring that out more but the AKG's made it much easier to pick out every instrument/voice, the Beyers were much more "compressed" in comparison.
I guess it boils down to where your priorities lie, if it's bass then go for the Beyers or if it's sound stage, mids and separation then go with the AKGs. The Q701's might be a good compromise but they cost more and depend on your hair.
