MSI Afterburner 3.0.1 Download Stable Beta
6 May 2012
Wigan
MSI Afterburner 3.0.1 Download -
Guru3D and MSI have been working hard on AfterBurner,
today we release an updated this revision of Afterburner,
this application successfully secured the leading position on graphics card utilities.
Download here
Thanks Scotty. Back to your best with these threads now. That's twice you've beaten me in recent times. :p
This version adds voltage control for 295x2 users.
I would love to see MSI AB getting an option for separate fan control options for each GPU.
It might be possible if you untick sync gpu settings. I know you can set difference OC profiles for each card. Each card having its own set of 5 saveable profiles each within afterburner.
I've noticed an odd error with this beta.
So my 7990 runs at about 38C idle and on the last stable afterburner this was the case, uopn installing this beta version my card idle's at about 55C!
Quite odd, I switched back to the stable version and my temps are reading at 38C again :rolleyes:
Sure its not just a reporting error? What does GPUZ say in both instances?
I know this beta added some 7990 stuff:
Fixed hardware database for reference design AMD RADEON HD 7990 and AMD RADEON HD 290X series graphic cards
What's your load temps on the card when its idling at 38c? Stock cooler?
Well GPUZ is currently reporting the same as the stable version, I will look at the beta again tomorrow.
Well at 38C I have zero load on the card, yeah stock cooler on the card. Kept cool by my corsair air 540 and all the cases fans replaced with more powerful fans.
The temps are fine, even when gaming at 1080P I only hit about 65C max, could just be a reporting issue like suggested I guess...
HAs anyone had their FPS overlay thing disappear from this? I have all the monitoring options apart from the FPS. :confused:
I had some guff from it yesterday telling me I'd added too many lines for the OSD, despite using the same amount in the previous version.
