haha - this isn't making a 290 look like a worthy contenderAlso, I don't really want a card which runs at 90c.
The 290 probably isn't for you then
Mine run at 93/94C
And 90°C red & black graphics cards which can't be overclocked.![]()
Yes. But not me.![]()
Ok, anyone running non-reference 290s in xfire?
Negative, im running reference 290's.
Are they sandwiched or is there 1 PCIE bracket between them?
Cheers Matt!!
Don't suppose you'd be willing to test crossfire with them in slot 1&2 would you?
Basically looking for temps and noise under load, so BF3/4, Batman if you have it. Don't really play much else.
Idle temps and noise would be useful also. This is helping me with my choice if crossfire, sk if its too loud/hot, I'll re think.
Will you be using vsync in BF3/4? I can do a quick lap of Unigine if you like with the cards in different slots? Will you be using a custom fan profile, if so what speed should i set the cards to? Will you use the auto fan profile? On reference cards this means you set a temp target (or leave it at the default 94c) and set a max fan speed to use to try and keep to that target. If you want the lowest noise possible then its best to set the temp target to 94c and the fan speed to 100%.
Blows the cost argument out of the water, but might solve the others...
How about an AMD 295X2?
@Nexus - Was that the reference model or the third party coolers?
I'd not thought about it in all honesty. I'll tell you what I'm after and you can suggest settings/config.
The case is micro atx so looking to vent out the back, PCIE slots are 2 spaces apart, so crossfire will be hot. I'm after a balance between performance and noise and after looking at the R9 290 reference noise tests, I think 65-75% would be the limit, ideally no more than 50% without loosing too much performance.
I would also be looking to limit the temp to no more than 80c, my MSI HD 7970 TF III was happy there, I didn't have an issue with that. In all honesty, you'll be better to advise me than me tell you as I've no idea the best way of configuring reference cards. I've just found an EVGA 780 SC on the MM for £400, so really debating where to go.....I'll leave the testing to you!
Oh - Will be moving to a 1440p monitor also over the coming months.
