Questions about Alphacool
12 Jun 2014
Manchester
I am building my first full custom loop at the moment (log in the logs section).
On a whim I decided to bid on some rads on ebay... 3x Alphacool NexXxoS Monsta 360, and I won them for a reasonable (very tiny) price.
My question is, are Alphacool NexXxoS Monsta 360s any good?
And if so what is the best method of cleaning them out? the previous owner used Mayhems X1 Red.
Thanks in advance!
Yes, they are good. Dunno where you're gonna put three of them though :)
Use hot water with a bit of distilled vinegar followed by distilled/deionized water to flush them out.
You may only get one of those in an h2...
Thickness wise in the bottom you have around 80mm until you hit the PSU, leaving no room for fans down the bottom.
I recently did a build in one with a pair of 480 sr-1's, those are 54mm thick and it was a bit of a squeeze down the bottom compartment.
The Monsta's are great mate, I'm running a 420, and a 480, in my Enthoo, to cool a pair of 7950's and a 4670k, and the temps on any never reach 50 degrees, that with 120, and 140 mm Akasa vipers all round in push pull.
