Images of items I have purchased.
Status
Not open for further replies.
60GB Phat with 4 games for £70 collected off Gumtree.
The Everything Is Awesome Edition is from USA only I believe. I bought it from DVDWorldUSA.com. The DVD is Region 1 but the Blu-Rays aren't
whats it do?
I was wondering that. The Manufacturers page was clear as mud!
Having found someone that sells its the description is as follows : "Low cost 2.4 GHz Access Point/CPE which connects directly to an antenna. Power and data are supplied over the ethernet connection."
Looks like it's reasonably weatherproof as well. Neat idea.
I'm going to use it as a wireless access point. but it can be used as well for creating all manner of wonderful wireless networking setups.
It'll take its ethernet feed from the shed where the rack is with power and then a single POE run out to the bullet :-)
Still needs an aerial but as it's not going mega distance, I think a cheap omni will suffice. It also has built in QOS/traffic filtering so it'll also have a friendly helping of that to stop my connection getting smashed.
Just because, "Everything is awesome!!"
Sucks that it's no out over here yet and and that we wont be getting the Vitruvius limited edition
I take it you ordered that from the states? Is it region locked? Did you just order that from Amazon.com and pay the delivery charge to the UK or did you do it another way?
You can get "The Lego Movie 3D (Limited Edition)" from the bay. Out on July 3rd in Australia and it's region B.
well it last a long time for corrosion, but it is incredibly fragile to impact damage (hence why we make the front bits out of metal still).
so not really ideal for something that gets banged around a lot lol.
Generally when I play cards there are no forces comparable to a plane crash, thankfully.
Nice trainers.
I just bought two Eagle F1 AS2 tyres 255/30/R19, cheapest I could find them was tyre leader. £312 for them both!
Nice trainers.
Goddamnit, why didn't I know about Tyre Leader, they've got a great selection of 255/40/17 tyres (including my preferred choice), much wider selection than Camskill... guess I'll be taking a look at that place when I need my next set.
Status
