basically my original benqxl2420t monitor back light bleed had got worse over time and my warranty was nearly up i contacted benq and they swapped it for a supposed like for like monitor.
The first monitor they sent has parts missing from it and had even worse back light bleed and was not in a good condition.
The second monitor they sent was in terrible condition,had a scratch on the screen it had pads missing from under the base,scratch marks and scuff marks on the frame and base and it even had 2 5p coins stuck on the base of the monitor,plus really bad back light bleed,it was supposed to be my original monitor with a new panel thay said.
They sent me a refurbed doa monitor this time all seemed ok until i was using it at night when i noticed the back light bleed across the bottom middle it stretches across most of the screen and is worse than my original had it, when i tried to set up 3d vision I get to the part where it says 3d ready monitor found and click next some kind of black screen hides whats on the screen,because if i turn the monitor off and back on as it powers up you can briefly see the screen before it turns black again,sometimes you can make out through the black screen the 3d vision set up screen.
I have tried swapping dvi cables swapping usb ports for the emitor re installed win7,reset monitor,tried older nvidia drivers but to no avail it still does it.
I contacted benq about these issues they said the back light bleed is within the specs
wtf! benq said it must be my equipment thats causing the black screen,but the previous refurb was working fine with 3d vision and nothing has changed on my set up since.
It's hard to capture it i think but its worse than it actually looks.
