£1500 Gaming PC Spec
27 Feb 2006
around
OK, So here's what I've got. I already have an SSD/HDD/DVD drive so no need for them. My only concern is the i5, I really don't want any trouble with GTA V when it comes out and I still remember how bad GTA IV was at release. Do you guys think it's worth going for the 4790K or will the 4690K be enough? I can stretch for the i7 if need be.
YOUR BASKET
1 x Gigabyte GeForce GTX 780 WindForce 3x "GHz Edition" 3072MB GDDR5 PCI-Express Graphics Card £399.95
1 x EIZO Foris FG2421 23.5" 240Hz Widescreen Gaming LED Monitor - Black/Red £399.95
1 x Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £189.95
1 x Gigabyte Z97X-Gaming 5 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £119.99
1 x Corsair Obsidian 450D High Airflow Mid-Tower Case (CC-9011049-WW) £91.99
1 x Seasonic M12II EVO Edition 850W '80 Plus Bronze' Fully Modular Power Supply £89.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) £88.00
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (TXD38G2400HC10QDC01) £71.99
Total : £1,526.78 (includes shipping : ).
Why do you want a 240Hz monitor? That's really expensive, especially for a 1080p. 240Hz is overkill imo. You could easily slot in an i7 with the money saved, probably a 780Ti as well
I just want the best monitor I can afford really. It's not something I want to skimp out on and everything I've read puts the FG2421 up there. What monitor would you suggest swapping it out for?
I think a 240hz monitor is a waste too. Even with the Best single GPU (780Ti) you won't be getting over 100-150 FPS in big titles anyway.
You'll only see the difference between a 144hz monitor and a 240hz monitor when the FPS gets above 144, which is not going to happen often.
I'd go with a 144hz monitor and a 780ti.
YOUR BASKET
1 x Asus GeForce GTX 780Ti DirectCU II 3072MB GDDR5 PCI-Express Graphics Card £499.99
1 x Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £269.99
1 x AOC G2460PQU 24" Widescreen 144Hz 1ms Gaming LED Monitor - Gunmetal £199.99
1 x Gigabyte Z97X-Gaming 3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £109.99
1 x Corsair Hydro H105 Extreme Performance Liquid CPU Cooler (CW-9060016-WW ) £89.99
1 x Kingston HyperX 8GB (2x4GB) PC3-19200C11 2400MHz Dual Channel Kit - Black/Red (HX24C11BRK2/8-OC) £67.99
Total : £1,519.03 (includes shipping : £20.10).
or you could get a 27" 144hz or 1440p display and drop to the windforce 780. :)
YOUR BASKET
^^^^^^ Listen to this man
I never left just I am disappointed by the colour options of Z97 which is a bit of a bummer for a bling rig kinda guy ;)
I know, its Red or Nothing Really.
Dead set on Nvidia?
As much WOW bargains to be had with AMD - http://forums.overclockers.co.uk/showthread.php?t=18606407
This card is EPIC performance for the money
YOUR BASKET
1 x Gigabyte Radeon R9 290 OC WindForce 4096MB GDDR5 PCI-Express Graphics Card (GV-R929OC-4GD) £319.99
Total : £329.59 (includes shipping : £8.00).
That's if he isn't set on Nvidia. :)
P.S that AOC monitor is "much WOW" too, just make sure you use Duallink DVI to get 144Hz support, HDMI+DP dont go that high for some reason.
