** GREAT AMD DEALS FROM GIGABYTE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Some good prices from Gigabyte:-
Gigabyte Radeon R9 290X OC WindForce 4096MB GDDR5 PCI-Express Graphics Card (GV-R929XOC-4GD) @ £399.95 inc VAT
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but also enables higher performance due to a lower temperature.
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK,FAN, OSD, ONLINE SUPPORT and update driver, BIOS directly.
Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
Features:-
- WINDFORCE 3X 450W cooling system
- Core Clock: 1040MHz
Specification
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- Core Speed: 1040MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit>
- Memory capacity: 4096MB GDDR5
- Cooling: WindForce 3X 450W Cooling System
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required <br />
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort <br />
- Card size: L=294mm, W=141mm, H=41mm
- Warranty: 3yr
Was [£419.99] Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
Gigabyte Radeon R9 290 OC WindForce 4096MB GDDR5 PCI-Express Graphics Card (GV-R929OC-4GD) @ £319.99 inc VAT
Features:-
Specification
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950
- Stream Processors: 2560
- Warranty: 3yr
Was [£359.99] Inc. VAT
Only £319.99 inc VAT.
ORDER NOW
Gigabyte Radeon R9 280X Rev2.0 WindForce 3X OC 3072MB GDDR5 PCI-Express Graphics Card @ £223.99 inc VAT
GIGABYTE introduces the latest exclusive "Triangle Cool" Technology to reach a better cooling performance. The latest patent pending technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the new triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Therefore, the "Triangle Cool" Technology provides a more efficient air flow for the cooling system.
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. GIGABYTE Ultra Durable VGA can lower GPU temperature by 5% to 10%.
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. GIGABYTE Ultra Durable VGA graphic accelerators improve overclocking capability by 10% to 30%.
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. GIGABYTE Ultra Durable VGA can lower power switching loss by 10% to 30%.
Specification:-
- Litecoin Hash Rate: 550-750
- Rev2.0
- Black PCB
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 1000MHz
- Boost Clock Speed: 1100MHz
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 6000MHz
- Display Outputs: 1x DVI + 2x Mini-DP + 1x HDMI
- Power: 250W TDP
- 3yr Warranty
Was [£249.95] Inc. VAT
Only £223.99 inc VAT.
ORDER NOW
Gigabyte Radeon R9 280 WindForce 3X OC 3072MB GDDR5 PCI-Express Graphics Card @ £169.99 inc VAT
Specification:-
- Black PCB
- Core Clock Speed: 950MHz
- Boost Clock Speed: 1072MHz
- Stream Processors: 1792
- Memory Width / Speed: 384 bit / 5000MHz
- Dimensions: L=285mm W=126mm H=38mm
- Power: 250W TDP
- 3yr Warranty
Only £169.99 inc VAT.
ORDER NOW
