Best thermal pads for VRM's?
Can you get the Fujipoly extreme/ultra extreme pads here? Those are the best of any I have used. Warning- they ain't cheap, especially the ultra extremes.
If you fit the block right, even the crappiest pads will do the job and keep temps well under control, so i wouldn't worry about seeking the best pads out there for premium price if you cant find them.
The pads help out a lot with VRM cooling to help stabilize overclocking. I would say they are definitely worth it.
Brought some cheap akasa thermal pads of here, going to see if they help first, then if they don't will look at some other options.
For some reason I have been able to play BF4 and Assassin's Creed Black Flag perfectly since fitting this Gelid Icy Vision but try playing FM 2014 I get artifacts everywhere, tried verifying files but it hasn't helped even my temps are fine awhile trying to play it.
In my experience the EK ones that they use in their waterblocks are very good, you can buy them in squares or strips and in 0.5mm, 1mm, 1.5mm thicknesses. I've tried some other blue pads before (forgot the brand) and it was stiff like cardboard and didn't transfer heat very well.
