Let me know if you manage to overclock past 4.5GHz at lower voltage and temps compared to your 4770K.
I had 4.4ghz on my 3770k without any volt increases. I'll try the same with 4790k. Maybe 4.7 or 4.8ghz without volts??
When you say without added volts, do you mean you set stock voltage and then raised multi or just raise the multi with volts on auto?![]()
Just got dispatch email aswell, Finally last piece of the puzzle!
