 - 15 Feb 2012
Each time you cut it in half, you essentially double the amount of sandwiches you have.
I love tuna... no bones
Does this mean a bird in the hand is worth 2 in the bush ?
% increase is just the difference between months divided by the value of the first.
I know. I'm trying to calculate the long term trend.
All this talk of sandwiches is making me hungry... Lunch.
That's ok if you've got a constant increase from month to month, but I've got ups & downs. It's the long term trend that I want to get growth for.
Here's my data & the chart
What is the trend supposed to be showing here?
You haven't even got the months in date order so surely trying to get a trend line is meaningless?
Ffs. For y=mx+c if c!=0 the gradient percentage is (m/c)*100, so y=119.45x+51062 gives (119.45/51062)*100 = 0.234%
^ I don't think that's right. Looking at OP's graph, the trendline starts at about 52000 and ends at 55000. Resulting in an overall % increase of 5.77%.
This is harder than I thought and now I'm stuck. OP this thread may help:
http://www.excelforum.com/excel-general/672000-trendlines.html
So the trend is an increase of 0.234% per period, ie over 10 months you'd expect to have growth of 2.34%? That makes more sense.
1	100
2	110
3	120
4	130
5	140
Yeh it looks right but if I do a basic graph of this data:
Code:1 100 2 110 3 120 4 130 5 140
Clearly the % increase is 40% and the equation is y=10x+90. Following Tummy's method:
(10/90)*100*number of periods (4) = 44.4% i.e. not right![]()
Ignoring the actual answer for a second, I'm not sure if you are analysing the data in a meaningful manner. Correct me if I'm wrong but aren't you just drawing a straight line between the first and last data point and saying that that is giving you the 'trend over time'. Who says there is a trend over time at all, perhaps what you are extrapolating is simply the scatter in the data?
No. It's a calculated trend line and you can see that it's not on the first & last data points but slightly below.
