Application to change partition size
27 Oct 2005
Netherlands
Hello,
One of my relatives has a problem with his C:\ drive being to small, so I want to nib off some of the D:\ drive and add that space to the C drive. I know disk manager but his windows Vista is SOOOO slow, I'd prefer to do it with a 3rd party app, prefferably a bootable one.
So, is this possible:
- Remove about 10-20 GB's from THE START of the D:\ partition ( and obviously, move that data forward if there is any data there).
- Add that space to the c:\ drive
What application is best for this ? Can I do this in Ubuntu for example ?
If I do this in windows this will take me HOURS due to the slowness of that guy's system.
Basically you don't want to hang around at your relatives house for a few hours while it does its stuff then.
Go for 10 mins, install teamviewer. Do from home?
i'd backup the whole d partition and then delete it. then extend c using disk management. create a new d partition and copy the backed up files back.
doing this will be far quicker than trying to resize a partition with the data left in place.
If anything on d is important then you should be making a back up before changing anything! Wholly irresponsible of not.
A ubuntu live usb had gparted which will do what you want.
MEH I just disabled system restore for now and told him to just buy an SSD in the near future.
Few g's of space back.
Don't understand some of the pre-built pc's of people, who in their right mind makes the c:\ partition only 39 GB :( ?
At least the ''users'' folder is on the d:\ drive, but still, I don't get it.
Try running ccleaner to get rid of temp files etc. Can free up an extra few GB.
One trick I've used is junction points.
Cut/paste large programs and things from the C drive to the D drive then do:
Code:
mklink /J "C:\Program Files\ReallyBigProgram" "D:\Program Files\ReallyBigProgram"
You'll see a shortcut in C:\Program Files which points to the copy on D drive, you can interact with this 'shortcut' as normal but in the background it's actually talking to your D drive.
The benefit of this method is you don't need to reinstall your apps.
