250mmx250mm 25 cm Case Fans / Where?
8 May 2008
Essex
I have tried searching the forums for this issue without much luck. My problem is that I have purchased the Armor Tower quite some time ago and I am very happy with it however the case has a 25 cm side fan and I would like to replace it but cannot find any 25cm fans... what are my choices?
you could try and post a new product request in the forums. might work.
you can also get them from the US but the postage will probably suck!
you could always buy a cheap side panel with 25cm fan... a quick google for 25cm or 250mm fans show a thermaltake side panel with fan for about £24... which would likely be cheaper than ordering just a fan from the US.
Also we can't technically suggest other stores as it's against forum rules
Well if OC doesn't stock the parts why would it be against rules? It would suck getting a new panel just for the fan when my panel is as new:( had a look at the 25cm from US bloody expensive to get it over, could always ask a mate when they go over.
What about putting 4 x 60mm fans next to each other making the 25cm? or 2 x 120mm
