- 14 Jun 2014
- Surrey
So quick question just came into my head. Tried to Google it with no definitive answer. I'm not concerned with one make vs another make or company vs company.
QUESTION: Are 2 smaller radiators better than 1 large one?
EXPLAINED: The first option you have is two small identical radiators with equal fin density and depth, say 2x 120's long. In the other hand you have one large rad, same fin density and depth as the 2 smaller rads but the only difference is that this one rad is twice as long at 4x 120s long.
Which would be better or would there be no noticeable difference?
The difference is the 480 rad would require less overall space, 1 less end tank
