Hi guys,
After searching multiple forums on this topic, I am still non the wiser as to;
1. wether there is actually a Windows 8 OEM and retail version - some say they are both the same
2. The OEM version is tied to the motherboard
For some reason there seems to be a mix of contradicting views on the topic. It would be really helpful if someone could back up their claims with direct links to Microsoft's terms and conditions (rather than just hearsay).
On Microsoft's Licensing FAQ, it states that
Can I purchase OEM system builder software for personal use?
A. For Windows 8.1, if you are building a PC for your personal use or installing an additional operating system in a virtual machine, you must purchase a full packaged retail product, not OEM system builder software.
This implied that there are two separate version (OEM & Retail)
Also,
Q. Can a PC with an OEM Windows operating system have its motherboard upgraded and keep the same license? What if it was replaced because it was defective?
A. Generally, an end user can upgrade or replace all of the hardware components on a computer—except the motherboard—and still retain the license for the original Microsoft OEM operating system software. If the motherboard is upgraded or replaced for reasons other than a defect, then a new computer has been created. Microsoft OEM operating system software cannot be transferred to the new computer, and the license of new operating system software is required. If the motherboard is replaced because it is defective, you do not need to acquire a new operating system license for the PC as long as the replacement motherboard is the same make/model or the same manufacturer's replacement/equivalent, as defined by the manufacturer's warranty
See http://www.microsoft.com/oem/en/licensing/sblicensing/pages/licensing_faq.aspx#fbid=q33zH_Ck5nq
There's seems to be a full retail version of windows 8.1 on Amazon, which is only marginally more expensive than the OEM 'advertised' version.
I really would like the option of transferring the OS to a new Mobo.
Cheers
Also,
Cheers
