Thanks for the information. I guess as Haswell is still (relatively) new maybe it's too soon to see how extra voltage and/or heat effect the lifetime of a chip. I'm not even sure how long they are designed to last for in the first place!
As this is my first build and I want it to last 3 years or so I'm trying to figure out what to do. On one hand I've got a K-series chip and a decent cooler, so want to tweak it and find a little extra performance. On the other, I don't want to have the chip fail within say 3 years, especially if the gains from overclocking aren't noticeable! I use the PC for work (basic office stuff), study (more office stuff and some light cryengine / unity work) and gaming.
Maybe I'll have a play with it again this evening and see what voltage I need for 4.2GHz. Something of a compromise!
I think a sensible 4.2ghz aim is a good fair one.
As you said 4.4 needed 1.3v , I would say try 1.25-1.28v
anything under 1.3v on Haswell chips is stock voltage. As mentioned most cpu would consume 1.3-something using boards stock power options. My current 4670K used 1.33v on stock for 3.4 - 3.8ghz turbo
I am currently 1.301v but at 4.6ghz
temps are in check and have good ventilation.
Going over 1.3v is a grey area. Its basically what your comfortable with. I dont honestly believe you would cause serious issues to these chips at anything under 1.4v but its a risk.
Go back to the Q6600 , and the i7 920 processors. How many still around ? lots, with many folk having huge overclocks on those processors for all these years. I personally bought a i7 920 , ran it at 4.2ghz 1.34v since 2008 solid 24/7 - my dad now owns it , back at stock and its running perfectly as ever.
So as long as we keep some sort of sensible guide, im sure things will not get ugly. And to be honest none of us here ever keep a system longer than 2 years anyway ......... lmfao
After some testing, I've settled in the end at 4.7Ghz for 24/7 use @ 1.32v
Idle temps 27C - 33C
Load temps 50C - 60C
Prime95 temps 77C - 83C
Speedstep enabled & Adaptive mode so 99% of the time, the cpu is downclocked and receiving ~0.7v
I think I could get 4.8Ghz out of this cpu, but I'd have to go to around ~1.4v which isn't worth it. Very pleased overall with this oem chip, picked it up second hand from someone who hadn't overclocked it for a measly £110
Now to look for a second Ti...
Hey e36Adz
Man you do seem to have a decent 4670K there. Were pretty much on par , but im 4.6 / 1.3 ,,,, just got 4.7 booting but was trying 1.37v ........ bit too much for my liking though.
I have had Q6600,Q9550,I7 920,I7 2600 and by far the most impressive is this little 4670K. Love this CPU
Well done , keep up the good work.
