Hi Guys
After a long wait, we finally have stock of the fantastic IN WIN 901 mITX version.
These cases are pre discounted for your convenience and available to buy online AND in our shop
AMAZING.
IN WIN 901 Design Mini-ITX Tower - Silver @ £119.99 inc VAT
The In Win 901 Mini-itx Tower Case brings In Wins award winning innovations to another level, with the stylish hairline texture surface design and the ease of use of the case, and great cooling capabilities, with the ability to house most GPU and cable management that will keep your components looking clean and tidy, and how else would you like to show your awesome gear off with the toughened glass side panel. This is an ultra premium, Unibody design at a perfect price point.
Specifications:-
- Dimensions: 173 x 350 x 400 mm (W x H x D)
- Material: Aluminum (Body), tempered glass (side panels)
- Weight: 6.71 kg
- Color: Silver
- Form Factor: Mini-ITX
- Total fan possible:
- 1x 92 mm (rear)
- 1x 120 mm (I / O panel)
- Radiator Mountings:
- 1x 120 mm (rear)
- Filters: I / O panel (remove)
- Drive Bays:
- 1x 5.25 inches (external, tools)
- 2x 3.5 / 2.5 inch (internal; tools)
- 2x 2.5 inch (internal)
- Power Supply: Standard ATX (optional)
- Expansion Slots: 2
- I / O Panel:
- 2x USB 3.0 (internal connection)
- 1x each Audio In / Out
- Maximum graphics card length: 300 mm
- Maximum PSU length: 200 mm
- Maximum CPU cooler height: 130 mm
Only £119.99 inc VAT.
ORDER NOW
IN WIN 901 Design Mini-ITX Tower - Gold @ £144.95 inc VAT
Specifications:-
- Weight: 6.71 kg
- Color: Gold
- 1x 92 mm (rear)
- 1x 120 mm (rear)
- Drive Bays:
- I / O Panel:
Only £144.95 inc VAT.
ORDER NOW
AMAZING.
Specifications:-
- Weight: 6.71 kg
- Color: Silver
- 1x 92 mm (rear)
- 1x 120 mm (rear)
- Drive Bays:
- I / O Panel:
ORDER NOW
Specifications:-
- Weight: 6.71 kg
- Color: Gold
- 1x 92 mm (rear)
- 1x 120 mm (rear)
- Drive Bays:
- I / O Panel:
ORDER NOW
