How to remove oxidation from new rads?
27 Apr 2012
London
I bought 3 new XSPC radiadors, 2x AX360 and 1x AX120 and you can see the oxidation on the cores.
What is the best and safest way to remove the oxidation?
You can see the difference in color between them, the oxidation on the AX120 is not as bad as the AX360s.
rads:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-180-XS&groupid=962&catid=1523&subcat=1526
http://www.overclockers.co.uk/showproduct.php?prodid=WC-175-XS&groupid=962&catid=1523&subcat=1524
I wouldn't bother with it tbh. But if you must, ketchup should do the job but it'd be awfully messy.
I was thinking about vinegar and rinse with deionized water, because I want to paint the core, so I think would be better to remove the oxidation before painting.
What paint do you intend to use on the core ? As you need to be very specific with what you use as not to imped the cooling performance.
I'm really not sure what to recommend, copper/brass cleaner like Brasso would do the trick but you can't physically clean the fins so you need something you could just soak it in that would attack the patina but not the copper.
*EDIT*
XSPC claim they are "passivated to slow oxidation" which put simply means they come pre-oxidised to shield them from further oxidation.
you want them to oxidize - shiny is bad for radient heat transfer.
Higher the emissivity the better
shiny copper - 0.05
thick oxide layer - .78 (that over 10x better)
and unlike paint that has a slight insulation value, the oxide layer is chemically part of the metal
rads are usually painted with a thin layer of black paint - 0.8
but if you can find a Black Epoxy Paint (0.89) or Matt Black Silicone Paint (0.93) that's even better.
Spray cans are available for use on engine blocks / exhaust headers etc
what I don't know is if the oxides act to protect the metal underneath (like aluminum)
or it just keeps eating the metal like in iron / steel
As copper is non-ferrous like aluminum I guessing it a barrier to further corrosion
Edit: it's a protective patina or Pilling–Bedworth ratio of 1.75 (below 1 bad, above 2 bad)
Not really true, patina has minimal effect on direct heat transfer like a heatsink or CPU block, but in the case of radiators which heat mostly via convection (the name is a misconception dating back to the 1800's) it impedes heat transfer and can have quite a serious effect in severe cases hence why radiators are normally protectively coated.
I would guess so as XSPC pre-oxidise these radiators to protect them from further oxidation.
Reading some more I agree the crystaline structure of the oxide will impede conduction of heat from metal to air (significantly reduced the thermal coefficient).
And I guess thinking about it more any radient heat loss from the fins will be reabsorbed by the fins opposite (been using radient panels in my passive loops for two long)
But once the heat /energy is in the air, the oxide should not affect convection in any way. (copper oxide doesn't form massive flakes like rusty iron)
conduction (heat from rad to air)
Convection, fan assisted (air to outside case)
