Affordable 1440P, When ?
19 Feb 2007
Sol
So with the introduction of £500-£600 4K monitors when will we see affordable 1440P monitors ?, By affordable I mean in the £200-£300 price range.
I would love to get the Asus PB278Q 27" at £479.99 but when put next to the likes of the Hazro HZ27WiE 8-Bit 27" which is also 1440P but at only £299.99, Having seen both side by side the picture quality is identical and to be honest I'm not sure where the extra pounds are going with the Asus model, Warranty support maybe ?
Anyway back on track, Whats the general consensus, How many more years until we see 1440P be as cheap as some 1080P monitors ?
Still atleast 18 months off IMO - once 2nd generation of 4K monitors start hitting the sub-4K panels will probably drop a bit in price.
I've used them 3 times and they've been poor :p
I sent back a faulty motherboard to Asus last year as the LAN port was DOA but I didn't realize this at the time as I was using a wireless network card and by the time I noticed I couldn't return it to the place I got it from *Not OCUK*
But it took them 3 months to return the working one, I phoned them up once a week and they gave me the same spiel every time "It's still in the pipe line"
Not even an exaggeration on the time there :(
They did give me a free 8GB USB stick for waiting so long though haha :p
As you say, not Asus's fault but the company they used.
Point taken though :)
Still ASUS fault for using companies like that to try and keep costs down. With the premium you pay for most of their stuff you'd think at the very least you'd get good customer service and quality control.
Similar story for me albeit quite a long time ago now and AFAIK was through Asus directly - 3 replacement refurbished motherboards each worse than the one before, none lasting more than a few weeks. Turn around was quick but it ended with a hammer and buying other brands for motherboards.
I've not really had any issues with other Asus hardware though aside from an "8800GT" that was actually an 8800GS but badged, labelled and boxed as a GT* which was a nightmare to get sorted as the retailer would keep testing it and returning it as "working" as obviously it worked but it needed someone a bit more technical really to spot what was wrong with it:
http://aten-hosted.com/images/8800GTGS.jpg
http://aten-hosted.com/images/8800sticker.jpg
Sticker was worn and tatty on an otherwise completely new, clean, retail boxed card. goodness knows what happened there.
In the end the retailer finally caught on and did adequately compensate me but it should have been Asus that made amends.
* Even had GT BIOS and all 512MB VRAM physically on the board but above 384MB was inaccessible and the extra SPs has been "laser cut" - later turned out was actually a GS core on a GT PCB.
This to be honest, if you are charging top dollar, and Asus are, then the warranty\rma\customer service has to be top notch. :)
