- 6 Feb 2010
I totally agree it is not needed from consumer point of view. But I was merely pointing out the possible reasons "for AMD" to do it. If the Tonga is cheaper to make than Tahiti Pro, not only they would be able to reduce production cost, but boosting their profile with the "new architecture" or "new releases", regardless of it is really needed to replace the Tahiti or not.They already have the 'HD 7970' 'R9 280X' in response to GK104. What we don't want is this card to re-branded once more. Unless it's coming in at the low end this time, at least that would indicate a shift in performance for the higher end cards. If HD 7970 AKA R9 280X is once again rebranded for the midrange than it's set to look very dull until 20nm and some new architecture arrives.
The 280 and 280x was boring because it was straight rebrand (and relatively high power consumption and hot for the bracket that' they are seating on), but "lower power consumption and heat", "performance of GTX670 upward to sitting between the 280x and the power hungry 290" could be attractive for some. It's worth bearing in mind there's no doubt be people can't wait for 20nm, and is only willing to spend around £200 for graphic upgrade.
I'd not noticed they were both dvi-d's. Been so long since I connected anything with VGA that I kinda forgot about it.
