First time watercooling setup, let me know if I have missed anything out or if there is something I can save a bit of money on it's already getting expensive, unsure if the pump is too much, the most important thing for me is low noise, I want to have the quietest setup possible.
Can someone link me up what I would need to add to the loop somewhere to easily drain it too.
Aesthetically I have a blue mobo and blue led avexir ram, I also have a bunch of blue LEDs lighting my current case at the minute, pic of the inside of my current case here. As you can see from the liquid I want to go with blue and green, the LED lights already pick up the UV so I think it will look pretty nice.
One thing I'm a little unsure about is the bitfenix cables, should I go for the blue linked in the spec or the green ones to go with the liquid?
YOUR BASKET
1 x OcUK Tech Lab - XSPC D5 Vario Pump & XSPC Acrylic Tank Reservoir Value Combo £99.00
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW) £98.95
1 x EK Water Blocks EK-FC R9-290X - Acetal £73.99
1 x EK CoolStream Radiator XT 360 (120.3) £48.98
1 x EK-Supreme LTX CSQ Intel CPU Waterblock £29.99
1 x Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Dual Pack (CO-9050012-WW) £25.00
1 x BitFenix Alchemy Cable Bundle - Blue £21.95
1 x Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Single Pack (CO-9050011-WW) £13.99
2 x Mayhems X1 UV Green Premixed Watercooling Fluid 1L £7.99 (£15.98)
2 x Primochill Primoflex Advanced Tubing 13/10 - Clear £5.99 (£11.98)
10 x XSPC G1/4" to 1/2" Barb Fitting (Black Chrome) £1.79 (£17.90)
11 x PrimoChill Black Steel Spring Clips - 1/2" £0.70 (£7.70)
Total : £479.45 (includes shipping : £11.75).
Thanks for any help
YOUR BASKET
Thanks for any help
