 - 26 Feb 2010
 - Surrey, UK
Hey guys, could use some help here.
So I bought a new AOC G2460FQ this week, as advertised here:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-024-AO&groupid=17&catid=510
So, I can't get this thing to run in 144Hz or anything higher than 60Hz, no matter what I try..
It didn't come with a dual link DVI cable in the box, which was pretty annoying, but I have one now. I have tried the monitor in 2 separate systems, one with a GTX670 and one with a GTX460.
Same problem with both.
If I try and enable 100Hz / 120Hz / 144Hz mode through either control panel or NVidia control panel, I just get a black screen and then it reverts back to 60Hz.
Here is a pic of my NVidia control panel options:
http://imgur.com/cFIozer
Anyone got any ideas, or anyone got any idea what support I can contact at this time to try and figure out why the higher frame rates are not working for me...?
Also, if anyone who is running a 144Hz monitor can confirm that their settings look the same as mine (especially the "connector" option) - that would be great.
Thanks.
Thanks.
