Caporegime
- 21 Jun 2006
i got some of them orb covers , not to bad.
i bought them in the past for my PS3 controllers and they were crap they just fell off with use.
are the PS4 one's a much tighter fit?
i had rubber peeling issue on ps3 as well but it took several years to get into the state my DS4 was in within 2 months.
that's why I tried them on PS3 but in the end I just opened the controller up and replaced the sticks for a couple of quid from ebay.
rather replace the sticks than use a cover tbh so long as I don't kill the controller in the process, which is easy to do since some parts inside are crappy thin plastic.
so it's a difficult situation to be in, i'll need to see some DS4 videos on youtube and see if it's easier to replace than DS3 sticks.
DS3 internals were crap the original Six-Axis controllers were far better built.
