2025mhz!?
Core blimey
Brilliant.
2025mhz!?
Core blimey
Is there anything above LN2 (helium?) and is it allowed in these comps?
It must be just me that finds these LN2 cooled CPU/GPU benchmarks utterly pointless.
If they were achievable under air or water fine.
Is their a point to them at all, apart from manufacturer e-peen?
There's just not the technology in place to super cool components 24/7 sensibly![]()
The technology is there, plenty of engineering applications need constant cooling at very low temperatures. It would add many tens of thousands of quid to the cost of the card though!
Motor racing has had lots of benefits for normal road use over the years.
Can anyone translate that 2GHz means for 780Ti? For example how much faster it is than a stock 780ti in, say, 3dmark. Cheers
