LG 34UM95-P User question.
10 Jun 2014
Hi guys
I am now on my second LG 34UM95-P I bought it to go with my trash can Mac Pro and PC.
The display is awesome for the audio editing / recording work I do but I think I may have a issue with the USB ports on the monitor and would like to ask a massive favour and see if anyone here could test something for me ?
My issue is that I have the display connected over thunder bolt to the Mac Pro and then I put a USB self powered drive or SSD in a enclosure connected to the USB 3 port.
I can then see the drive but can't use it it will actually crash my Mac Pro and I need to hot plug the drives to get the mac running again
I have spoken with Over Clockers who I have bought it form and they are having the same issue on PC
I can use it if I use a USB data + power cable and connect to 2 ports on the monitor then the drives work fine.
Spoke with LG t and they told me that there is no known issues doing what I describe ( i am now waiting to hear back from them again since this is the 3rd monitor I know of with this issue )
Has any one else ran into this problem or could perhaps please test it with a few USB 3 self powered drives?
I've tried Samsung evo SSD's in various enclosures OCZ vertex 460 drives in various enclosures , WD my passports , WD elements , oand a load of other various drives but all the same issue unless they are mains powered or I use the double cable.
Pen drives seem to work fine as do keyboard or mouse.
Would really appreciate if anyone else could test there ports with a few drives?
Thanks to all for any help.
Oh and for anyone interested in seeing the monitor in my setup it is here
https://www.facebook.com/Norrie.Chr...06558416719.1073741832.100003921334468&type=1
ReplyQuote MultiREP+
Sounds like you're simply trying to pull too much power from the single usb port rather than a fault, why not use a powered hub?
My 95-P (which I rma'd for other reasons) was fine for pen drives but I didn't try a hdd. Pg 17 of the manual recommends using powered drives though.
I agree with RichL, everything I've plugged in has worked including a 360 wired controller.
My Powered HDD's also work fine, so it seems the port can't supply enough power.
I wouldn't recommend constantly trying to do what you're trying, I remember killing a USB port on my 2009 Mac Pro.
I agree with RichL, everything I've plugged in has worked including a 36shoulded controller.
Thanks for the replys guys.
I spoke with LG and they told me that it should have enough power from the USB 3 port on it and I should RMA it due to it being a fault.
Although I do have my work around so it's not a major issue the tecs at OC also say it should work but it is crashing there test rig when a drive is connected.
Hmm must be a faulty one then, although unless you can get a guaranteed 1 week replacement I'd be iffy dropping work to replace it.
One of the reasons I tend to keep my older monitors around for ages.
They have stock for a replacement.... only problem is this is my second one and it's the same on the one OC are testing yet LG continue to say it should be fine.
I am perhaps wondering if there is a bad batch.
can any one test this please ?
